I HAVE AN ISSUE WHERE I HAVE FIRE EXTINGUISHER CABINET (SPECIALTY EQUIPMENT CATEGORY) PLACED THROUGH AND ON EVERY LEVEL. FOR SOME REASON THE FAMILIES ARE SHOWING UP ON LEVELS THEY ARE NOT HOSTED ON. MY VIEW RANGE IS SET FOR THE BOTTOM & VIEW DEPTH - ASSOCIATED LEVEL
If you wouldn't mind attaching the family, I will check it out. Don't worry, I won't use it. I have no need for fire extinguisher cabinets. ![]()
If there are model elements in the family that extend into the other levels it will show up in those levels.
sorry about that. let me try the attachment again
It only shows up for me at the associated level. I would say double check the view depth. The family also doesn't have any geometry protruding above or below the level, so.... it should work fine.
The family looks fine. The problem is probably in your view settings.
