I have a generic model (non hosted) family that I need to rotate between horizontal and vertical.
However, when I rotate, it is rotating from the Ref. Level point of view. You can see here the Trim stays horizontal and now you are looking at a side profile of it:
Can I switch the rotation of the family or is rotation always based on the Ref. Level in the family editor?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You can rotate a non host Generic Models family on an elevation. because it is still host by a Level. Workarounds:
- Make it a face based or work plane based family, and host it on a vertical work plane
- Change the family category from Generic Models to Mechanical Equipment or Fitting, make sure to tick Always vertical box, then you can rotate it in any direction in the project.
I did not have any luck with getting the family to rotate after changing the category and selecting always vertical. The rotation only on the Ref Level and not the elevation plane. The solution in my case will probably be using an addition family or type. Thanks ToanDN.
No you don't need additional families just so you can rotate them. Share the original family here.
So, I am avoiding all face-based or face-hosted families. It needs to be work-plane based. This is due to using these in groups and mirroring these groups. The non-work plane families I have been running into copying/mirror errors with groups.
Family attached.
You can rotate this however you want. No issues in groups either.
I can rotate in a plan elevation view, but not in 3D view. Do you know if it is possible to do this in 3D view?
Yes. Set a work plane for the rotation then rotate.
