Family Revit
5 ANTWORTEN 5
Nachricht 1 von 6
404 Aufrufe, 5 Antworten
Family Revit
I have 3D solid model make from Solidworks. I export to ACE sat file. I import it in Revit Project and save it.
My question is how I can save it to family file .rfa and will open from family files or project file.
Please tell me how should I can do.
Thank you very much.
Best Regards
Kevin Nguyen
5 ANTWORTEN 5
Nachricht 2 von 6
jeremytammik
als Antwort auf: Anonymous
Dear Kevin,
Is this a Revit API issue, or an end user question?
Are you doing anything programmatically, or just using the standard Revit user interface?
If not, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to product usage and end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
http://forums.autodesk.com/t5/revit-api/this-forum-is-for-revit-api-programming-questions-not-for/td...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Nachricht 3 von 6
I am Revit user. Would you please ask someone help me.
Best Regards
Kevin Nguyen
Engineer
[cid:image001.jpg@01D27266.346C2920]
4011 West Carriage Drive, Santa Ana, CA 92704 USA
kevin.nguyen@smithspower.com
T: +1 (657) 218-3308
www.smithspower.com
[cid:image002.jpg@01D27266.346C2920]
PROPRIETARY: This e-mail contains proprietary information some or all of which may be legally privileged. It is intended for the recipient only. If an addressing or transmission error has misdirected this e-mail, please notify the authority by replying to this e-mail. If you are not the intended recipient you must not use, disclose, distribute, copy, print, or rely on this e-mail.
Nachricht 4 von 6
jeremytammik
I asked the forum moderator to reroute your question.
Jeremy Tammik
The Building Coder
Nachricht 5 von 6
Hello Jeremy,
Have a nice weekend
Kevin Nguyen
Engineer
[cid:image001.jpg@01D272F7.F63F5540]
www.smithspower.com
[cid:image002.jpg@01D272F7.F63F5540]
Nachricht 6 von 6
Import the SAT file in a family instead of a project.
