Family properties and parameters on Project sheet
Hi!
I want to create description sheets of the different families that are in the project. Like a catalog sheet for each family, with the parameters and so. It is not a schedule table, that is showing all the families together.
Is there any way to create that?
Thanks a lot!
Cristian
L.Maas
I think you will have to resort to Dynamo for this. When you create a multi category schedule not all parameters can be selected for the schedule.
With dynamo you could extract parameter data and then export it to excel.
Louis
Please mention Revit version, especially when uploading Revit files.
Thanks!!!
loboarch
I don't think you have to resort to Dynamo for this. You can open the family in the family editor and then use the "Export > Family Types tool from the Application menu.
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-97656C18-26B8-469C-BA94-3B9EA6CC1BEF
This creates a CSV file of all the parameters that could be opened in Excel.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
