Family parametric question
2 ANTWORTEN 2
Nachricht 1 von 3
whrudwls111
256 Aufrufe, 2 Antworten
Hello.
You created the parameter "height" using the family parameter. Load into the project and add a different value.
Then you must lower all 60 because there are changes.
This is a family parameter and no values are displayed because the schedule will be lowered after it is created Is there a way?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: whrudwls111
It's not clear what you are saying.  Can you post some pictures?
Nachricht 3 von 3
Samantha-G
You will need to verify that your "family parameter" is a type parameter.  If it is an instance it will only change the current selection.  Within the family editor, check your height parameter, make sure it is type, then you can create different types, with varying heights.
Sam G, CM-BIM
Revit Certified Professional
