Family parameter not working when inserted
2 REPLIES 2
jonathan.parsons1
203 Views, 2 Replies
Can someone please try the attached family and tell me why it doesn't work when I switch between the two types (A306 and A307). The 'Bench Width' parameter does not change with the bench 'Type'.
I imagine it is a simple error as it is the first time I have tried to do this.
Tags (1)
2 REPLIES 2
Your parameter is instance-driven and not type. Either change it to type or put this formula for example:
if(A307, 1300 mm, 660 mm)
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Excellent. Thought I had tried the Type type but must have messed it up.
Formula is great, thanks
