Family Parameter Conflicts
23 ANTWORTEN 23
Nachricht 1 von 24
amirCKP
1534 Aufrufe, 23 Antworten
Hi guys.
I had a problem with importing some families (Specialty Equipment) into project.
This error appear. I already remove the parameter mentioned, and try load back to the project, but still the error come up..
any idea? any solution?
tq
Beschriftungen (2)
23 ANTWORTEN 23
Nachricht 2 von 24
ennujozlagam
als Antwort auf: amirCKP
post your family so we can check. thanks
Nachricht 3 von 24
amirCKP
als Antwort auf: ennujozlagam
Hi @ennujozlagam , attached is one of the families that got problem. Thank you
Nachricht 4 von 24
ennujozlagam
i don't find any issues? thanks
Nachricht 5 von 24
amirCKP
@ennujozlagam eh why you can load? haha.. is it you are using 2016 revit, and i use 2018, the issue on the revit 2018 version?
Nachricht 6 von 24
ennujozlagam
try to save your family Revit 2018 and try to load again?thanks
Nachricht 7 von 24
ennujozlagam
i dont find any issues in Revit 2018. try to install latest updates from autodesk and see if helps. thanks
Nachricht 8 von 24
ennujozlagam
revit 2018.
Nachricht 9 von 24
TripleM-Dev.net
The message indicates that there's a shared parameter in the project (or another family already in project) AND in the family with thesame GUID but with different datatype. Weight = Number AND Mass for identical GUID's
Looks like a manual edit of a Shared parameter file is used....!
Solution (I don't know which is the original?), delete the Weight parameter and create a new Weight parameter from the Revit UI. It can have the same name, but wouldn't advise it!
Either in the Family or in the project/other families....
We don't get the message because the other (Weight as number with identical GUID) doesn't exist in our project.
- Michel
Nachricht 10 von 24
amirCKP
@ennujozlagam the issue is ssolved now. I got the idea when see your  videos. There is no issue if the family is load into new architecture project. It happen when i load to my project template. Now i have to find a way to remove the 'Weight' parameter in my project template. Thank you.
@TripleM-Dev.net yeah. The parameter clash with my project template. Do you know how to remove the parameter in the project instead of in the family? if i remove the parameter in the family, and load back to project, the error still happen.
Nachricht 11 von 24
Do you see Weight when you open Project Parameter list? If so, delete it.
Nachricht 12 von 24
amirCKP
@ToanDN nope. Its not there.
'Manage > Project Parameter' right?
Nachricht 13 von 24
Edit the Parameter in the Family and change it from Shared Parameter to Family Parameter. If you need it to report in Schedules, then create a new Shared Parameter named "Specialty Equipment Weight" or whatever. Just not "Weight".
Nachricht 14 von 24
TripleM-Dev.net
If the conflicing parameter "Weight" is not defined as Project parameter then it's in a existing family in the template.
It could be a not-placed family....
Create a new Project from the Project template, purge x-times until nothing further can be purged.
Now try loading the other family, if no message appears now, the parameter is in one of the purged families.
Other option is as @barthbradley mentions to change the parameter in the family with a new Parameter (I think you can replace te exiting parameter in the Family by another one, so no need to delete it first....)
- Michel
Nachricht 15 von 24
amirCKP
als Antwort auf: barthbradley
@barthbradley i tried you suggestion but the error still happen.
Nachricht 16 von 24
I don't see how that's possible.  Are you saying you are getting the exact same error message about conflicting Shared Parameters?
Nachricht 17 von 24
So do you want to keep the Weight (Mass) or the Weight (number) parameter? One of them need to be replaced.
Nachricht 18 von 24
TripleM-Dev.net
@amirCKP .
Maybe also share the concerning Project file (maybe purge/delete elements and save as compacted...if to large)?
Nachricht 19 von 24
amirCKP
yes the same error appear even though I change the parameter name to other word.
Nachricht 20 von 24
amirCKP
als Antwort auf: ToanDN
If can, I want to remove both of them. I didn't use that 'Weight' parameter at all.
