I would like to creat a parameter in my family for modify the angle of my solar protection.
When i tried to change it, each time , even when i lock it with a reference line or plan, it send me a error.
Anyone know how to solve it, without dynamo?
Thank you!
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
-The family is over-constrained, which is causing the error.
-The louvers are likely placed in an array, and perhaps controlled with a formula--which in itself creates a lot of complexity.
- You might try placing the louvers in a separate family. Then, use a reference line and dimension with a rotation instance parameter to control the angle. Test it and make sure it "flexes" correctly when changing the angle setting.
-Then load the louver family into the host family.
-Load into the project, and try adjusting the angle.
Thank you for your answer. I will try it as soon as possible and i will send you the feedback about it.
It's very paintfull to have so much over complexity on a such a small command property, unfortunably...
