Hi - I am working on a TV family that can be inset into a wall if an instance parameter is checked - see attached. To do this, I have the void (locked to a moving reference plane) that cuts the host/wall, set to move outside of the host the the parameter is checked. I've done this before to get around Revit's limitations when it comes to the visibility of voids in families. The problem is that when I uncheck this once it's loaded in the family, Revit throws up an error telling me the family isn't cutting anything and basically forces you to cancel the action or delete the family. In this case, it's by design that the void isn't cutting anything. Any ideas how to get this to work correctly (other than having two separate families)?
Note: If you're testing this, use a 6" wall. This is for a situation where I have a lot of deep walls and need to inset the TVs, trying to avoid a lot of manual manipulation of the wall types/layers/etc.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Make sure you used Cut Geometry on the Void and the Host wall. Revit will "remember" that the void is supposed to cut the wall when it is pulled away and cut again when it returns. It worked fine after I used Cut Geometry and reloaded it into the project.
Steve Stafford
Can you explain this in more detail? I did as you mentioned and enabled the "Cut Geometry" on the void in the family (it was my understanding that this parameter has no impact on the hosts, only other geometry in the family). In any case, it didn't work for me. When I toggle the "Inset TV" parameter on and off, Revit throws up the error and my option is to delete the family?
I didn't enable Cut Geometry... I used Cut Geometry (opposite of Join Geometry), picking the host wall and void so the void "knows" it is supposed to cut the wall. When I downloaded your family it generated the warning when I toggled the option to recess the TV. When I used Cut Geometry and reloaded the family it no longer generated the warning.
Steve Stafford
Why don't you make the Void parametrically-sized? When not creating a TV-sized niche, it's creating a screw-sized hole. In other words, it's always cutting the host. ![]()
What you are up against has been issue since Moses wore shorts. It's also been a repeated request on the "Wish List" (now "Ideas").
See if this family behaves, it does for me in Revit 2024. I only used Cut Geometry on the void/host.
Steve Stafford
Looks like you detached the void in the Family (so it isn't cutting host). So, you need to manually cut the niche in the Project wall using the Cut Geometry tool and picking the Family and the wall. Right?
...Whatever. I like it better than "Inset" TV Types personally.
I downloaded the file, opened it in Revit 2024, activated Cut, pick the void, pick the host. Saved the file, loaded into a project, placed on a wall, toggled between recessed or surface...no warnings. Uploaded the family to the forum.
One thing I'd have done differently. The void would be hosted on a fixed reference plane beyond the wall and then a parameter would extend the void depth so it cuts the wall.
Steve Stafford
