Hello everyone,
First of all happy new year and let this year Revit react the way you expect it.
I am looking to find the best way to get a statue (in this case a human bust) in a family environment. The requirements are as follows:
- needs to be in a family as I have multiple instances of the family at the project level
- It needs to be aesthetically pretty and accurate for rendering purposes. Materials are important even if it might be just one as a skin colour.
My starting point is a Point Cloud from a site scan. I have tried to mesh it but all it creates are triangles which are not aesthetically pleasing. Therefore, I thought that a surface might be more appropriate for my requirements.
I think there are multiple approaches here:
1. Photogrammetry
Go on site, take a lot of photos, use something like Recap Pro Photo to generate in the cloud a 3D model sufficiently accurate. Now I am not sure how to import that model into the family and keep the materials and intricacies of the surface. Will Rhino / Sketchup formats import properly in the family ?
2. Modelling as normal in the family environment
I am not sure how to bring the point cloud in the family environment (via DWG?). It seems counter intuitive as there will be a lot of manual modelling, and the family does not seem the best environment to model surfaces.
3. Point cloud to surface algorithm
Any used something like Python to create a surface from a point cloud? After a bit of research there seems to be a method called 'Poisson surface reconstruction' ?
4. Using freelancers
What format and software will be most appropriate for achieving my targets if we sub out the work ?
Any suggestions and thoughts on the best way to proceed will be highly appreciated.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Yes you can import Rhino or SketchUp model format in a family.
You can also generate a mesh from a point cloud via Recap pro then import the mesh in Revit via dwg format.
