Family Loaded into Project. but not in file directory
4 ANTWORTEN 4
Nachricht 1 von 5
710 Aufrufe, 4 Antworten
I have a Project that was created on a home computer. Now it's on a work computer, and I'd like to save the Families loaded into the Project onto the work computer. I have attached a screenshot of the Project Browser. It shows a subcategory of walls called "Basic Walls," all of which I would like on my work machine in the form of .rfa.
Is there a way to get the families loaded onto the project into my file directory? Are they there and I'm just not finding them? Or do I need to go home and save them on a flash drive? I'm using Revit 2015.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
You can transfer them to another project or template. You would need to open both and then use Transfer Project Standards on your manage tab.
Nachricht 3 von 5
ennujozlagam
hello, in addtion to @barthbradley my compadre suggestion, you can open your file in your work computer and go to file > saveas > library > you can choose three options to save in your folder. thanks
Nachricht 4 von 5
chrisplyler
What nobody has explicitly spelled out yet is that Walls, Floors, and several other categories are System families.
What it means to be a System family is that they are created only IN a project and cannot be saved as rfa files. There is no such thing as New>Family>wall.rfa for example. You can't create a wall type, or any System family type, outside of a Project file.
Nachricht 5 von 5
M_Perez
As @chrisplyler pointed, you can't not save/load system families. You could transfer them as @barthbradley said or you could just copy and paste them.
As a long term solution you should transfer/copy them to your template, Then you will have them in any new proyect.
