family loaded but not available
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
julia.geisler
490 Aufrufe, 4 Antworten
so i have a problem and i can't seem to find a solution. I tried to load a family into my project (TU Fassade - 2-flg-Drehflügel) and so far that worked. At least i can find it in the project browser but i can't find it when i want to place the door and choose the door tool.
Already tried different ways of loading it in but nothing worked. I just can't find it.
Am i looking in the wrong place for this door or could i have done something wrong?
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: julia.geisler
@julia.geisler
That's a door for curtain walls... its accessible when u unpin a panel and go to replace it from the type drop down menu.
For doors to place in basic walls, You need to load a different door from the library, a door family which is not suffixed or prefixed "Fassade" ... das heißt pfosten-riegel Fassade
Nachricht 3 von 5
syman2000
You have to create curtainwall and then swap out the panel for the door.
Nachricht 4 von 5
julia.geisler
Thank you both for the fast reply. I actually have a curtain wall in that project but i just couldn't figure out how to place it and didn't think of replacing a panel in the curtain wall cause i was so fixed on the door command.
Still trying to figure out a lot of things in revit.
Nachricht 5 von 5
RDAOU
You're more than welcome...whenever you have a question do not hesitate to ask....
