Family labels
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
semraozturk
436 Aufrufe, 3 Antworten
Family labels
how can I make the labels on my kitchen counter disappear? When I first downloaded the family it did't have any labels I don't know at which point they have appeared. I tried to delete them but when I do so I am left with a question mark as seen on the screenshot I am attaching.
Thanks in advance for any idea!
3 ANTWORTEN 3
Nachricht 2 von 4
timlove
als Antwort auf: semraozturk
It looks like you deleted the parameter, but did not delete the label itself.  you may have to search through different views, maybe even hosted families, or even unhide something to find it, but there is an object within your family that has it.
Nachricht 3 von 4
RDAOU
@semraozturk
Select the family and Check the properties  palette or type properties for a visibility parameter...often such families have them
Otherwise edit the family and associate the nested labels with a visibility parameter or delete the therein if not needed and reload
Nachricht 4 von 4
semraozturk
als Antwort auf: RDAOU
Oh yes this worked!
Thank you!
