Family is not visible
2 ANTWORTEN 2
Nachricht 1 von 3
Pal_Batki
189 Aufrufe, 2 Antworten
Hi
I made some families in Inventor and want to use them in Revit.
When I insert them I can not see the actual 3D model, only a few dimension lines indicating that the family is there, but it is not visible even on the 3D view.
Any idea what could be wrong?
2 ANTWORTEN 2
Nachricht 2 von 3
jay_colcombe
als Antwort auf: Pal_Batki
Hi, did you use the BIM Content Process?
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-D20CD536-0577-4253-BE0E-F07508BE1E81
If your happy to share the file we could look further and offer some more detailed analysis.
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 3
syman2000
Does your inventor object have a lot of curves? Try to change the shademode to shaded, consistent or realistic and see if the import object shows up.
