Hi all,
Trying to create my own timber batten with an instance parameter so i can 'pull' the end to desired length/location. For some reason the pull isnt showing on the family. Cant figure out why. Any idea?? Family attached
Gelöst! Gehe zur Lösung
Gelöst von rxi.gg. Gehe zur Lösung
You were missing a reference plane anchored to the base of the wall.
Now it works. I attach tou the modified family
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
