family Instance Parameter Greyed out
2 ANTWORTEN 2
Nachricht 1 von 3
1599 Aufrufe, 2 Antworten
I was following an old kinetic facade tutorial from: http://www.jrohdesign.com/revit/authorized_users/classes_2015s/index.html
This was done using Revit 2015 and an old version of dynamo.
As im using 2017 and dynamo 0.9.1.4062
Following the tutorial it to the letter is not possible as most of the nodes have been changed  or do not work as expected.
I modeled and made the family along with the parameters and created a new project and applied it to the mass surface now i am able to select it but not change the parameters as the parameters are Grayed out and in dynamo i get Read only error.
**in the file i uploaded i am able to select it and change it in project file and dynamo because i changed the parameter "NCP" into a type parameter**
** but i want it to be a instance Parameter and set the "NCP" parameter induvidually**
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
If you select the mass and clic "Edit In-Place", then you will be able to change the instance parameters too.
However, in order to control the parameter values in Dynamo, you could use the node "Select Divided Surface Families" (with "Edit In-Place" mode activated) and then select the mass surface.
I hope it helps, thank you for sharing,
Martina
Nachricht 3 von 3
I can select them but not change their parameters...it still gives me Read only parameter error.
What i did was create a mass family and apply the same pattern to it , then create a fake sun using point on spherical coordinate draw line from all panel point to the sun point and measure the vector angle between the sun lines and the individual point lines and somehow i got it to work.
Although the sun is not accurate ( i need a way to create an accurate sun in dynamo that works by azimuth and altitude ) after that i think this method is ok.... you still need to load the mass family in the main project each time to see how it looks on the Building.
This still needs a direct solution.
