Family-Host(locked)
4 ANTWORTEN 4
Nachricht 1 von 5
alejandroCH79K
346 Aufrufe, 4 Antworten
Family-Host(locked)
Hi Team,
How do we change this host when, for some reason, its locked in the properties(Family)
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: alejandroCH79K
https://forums.autodesk.com/t5/revit-mep-forum/quot-not-associated-quot-items/td-p/9003969
Nachricht 3 von 5
hmunsell
Not sure what that family is, but the parameter is not Locked, it reads the hosting state of that object after its placed.
By the name I would assume it would be Wall Hosted or Face hosted. Are you sure the family is a hosted family to begin with? not all family's are.  if you edit the family, it will tell you its hosting preference.
in this case its a Face Hosted Receptacle.
Howard Munsell
Nachricht 4 von 5
Nachricht 5 von 5
handjonathan
Hi @alejandroCH79K
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley @hmunsell @ennujozlagam helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
