for a project i am trying to make a family of a aluminum profile that can be stretched to make a wall of it.
first i made a generic model family of the profile itself.
then i loaded the profile into a new generic model family template.
i have allready set a height parameter and the spacing between the profiles.
the only problem left is to make it so that if i want a wall of 600mm the profile copys itself the needed amount of time.
i know this might be a bit of an confusing explenation but i hope someone can help me?
i have added some screenshots
An option could be to create your wall using a railing. Create the profile as a baluster and set the spacing in the railing family to suit.
You might also consider a curtain wall for this.
I would make the profile usage Curtain Wall Mullion, and create Curtain Wall Type in the Project. Vertical Layout = Fixed. Spacing= 60. Adjust for Mullion Size = unchecked. Use your Mullion Profile for Vertical Mullions. You can make the Curtain Wall whatever height you want.
