Family Extrusion Sliders
9 ANTWORTEN 9
Nachricht 1 von 10
thefoltyn
1353 Aufrufe, 9 Antworten
Hello there,
I have modelled two families which are simple extrusions, I can control their hight by typing the dimension in the properties table. However one of these families, which I created based on the first one, have the sliders visible in the views which allows me to easily adjust the height of the element. My question is what determines whether the sliders are visible in the views when the family is loaded in the project?
Tags (2)
Beschriftungen (1)
9 ANTWORTEN 9
Nachricht 2 von 10
ennujozlagam
als Antwort auf: thefoltyn
edit the family and set the visibility setting. thanks
Nachricht 3 von 10
thefoltyn
Well, the visibility settings are the same in both families. I want to see the sliders that allow the change of the extrusion length when family is loaded into the project.
Nachricht 4 von 10
ennujozlagam
then you need to add length parameters in the family itself. thanks
Nachricht 5 von 10
thefoltyn
I have the length parameter in both families, I think the case might be that in one family, where the sliders are not visible the length parameter is a shared parameter. Is it possible to have these sliders in case of shared parameter?
Nachricht 6 von 10
cbcarch
Check and see if the Reference Planes that control the Height Parameter in the family are set to "Strong Reference"--that should enable the "grips" or "sliders" once the family is loaded into your project.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 7 von 10
thefoltyn
Thanks for the replays, but it is still not this, in the one with the working grips, both reference planes are set to Weak.
Nachricht 8 von 10
cbcarch
The Height Parameters under Dimensions appear to be different in each example you posted. Try using the same one in the family where the sliders are not visible.
Cliff B. Collins
Nachricht 9 von 10
andre.micka
The sliders appears with planes in 2D.
If you use reference lines the sliders appears in 2D and 3D
You must create planes and reference lines in you family and lock your model to its
Nachricht 10 von 10
Is the Parameter controlling the Height an Instance Parameter? Is the Labeled Dimension pulled between Ref. Planes and the Extrusion ends Aligned/Locked to those two Ref. Planes?
FWIW: those "sliders" are called "Shape Handles" in Revit.
