There is the rub, more than one way to solve a problem. The more you know about what variables you are likely to want to manipulate the more likely you can build in logical constraints. They can be explicit constraints through dimensions and reference planes like in my crude sketch over your image or you can build in design logic via dimensions, parameters and formulas.
I use the metaphor Bones, Muscle and Skin to keep my work in the Family Editor focused. Bones (reference planes/lines) are sketched first to describe the rough skeleton of the family. Then I add muscle (dimensions/parameters), attaching them to the bones. I flex the parameters to make sure the bones follow the instructions passed on by me/Revit to them through the muscles. Once I'm satisfied that is working I add the skin of the family (solids, voids and lines if necessary), constraining them to the bones. Revit (and us) are the brain driving it all. Then test and flex it both in the family editor and in the project to be sure everything works as intended.
Everything written above assumes that what is required is a parametric family, potentially highly variable and comprehensive. That can take quite a lot of thought and time for some families. However, for things that are relatively inert, like custom built-in furniture, it is not required of us to build a parametric skeleton. We can just create the forms in the exact sizes we want them to be and save/use the family.
The real value in putting the effort into the parametrics of a family is discovered when we spend a lot of time refining its design. It takes some experience to know which approach to take and when.
Good luck!
Steve Stafford
