i need help please.
above the window we put a concrete bar (see attached). i created as a detail element in the family. now i need to align it with in the center of the core of the wall, not the center of the wall (core + finishing layers).
i attached the file also.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You need to add reference planes defining the center of the core in the family and constrain the lintel to it. Create a dimension from that reference plane to a face of the wall and label it with an instance parameter. Load it in project and you will be able to align the lintel to the wall core center without affecting the window placement.
i did that already but i didn't get the result i need
can u please do it in the family and attach it
