Family contains shared parameter which are not permitted
2 ANTWORTEN 2
Nachricht 1 von 3
Reed_Weinstock
220 Aufrufe, 2 Antworten
I'm noticing whenever try to create new geometry in family after I've added a shared parameter spelled the same as an OoTB parameter I get this error.
2 ANTWORTEN 2
Nachricht 2 von 3
SteveKStafford
als Antwort auf: Reed_Weinstock
This sounds a bit like, "Hey Dr. it hurts whenever I do this!" and they reply, "Don't do that!". We need to make our own parameters unique from those that are built into the system already, such as _Description instead.
Steve Stafford
Nachricht 3 von 3
Simon_Weel
Reading the error message, it looks like you try to change the Family Category, but the Category you picked already contains a default parameter that's the same as a shared parameter in the original Family.
Now 'Description' is pretty much used in all Family Categories, so I wonder what the original Family Category was and to what category you try to change it?
