Family Colorless
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
emersongonzalez1999
728 Aufrufe, 14 Antworten
Family Colorless
I download a family from Revit City it was a Truck Trailer its Colorful but when I load it to Revit is grayed out colorless. How can I make the truck appear as shown in Revit City?
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: emersongonzalez1999
Manage > Object Styles > Imported Objects > Expand Imports in Family > Assign materials to the truck's layers
Nachricht 3 von 15
syman2000
Is the material show up in realistic or shaded? If it is shaded, then they haven't add material to it. If it shows up in realistic, then they haven't make the graphic match the material. So anything you download from Revitcity require you to clean up before you can use it. Not everything shown in screenshot will appear when loaded into your project.
Nachricht 4 von 15
emersongonzalez1999
als Antwort auf: ToanDN
I don't see anything related to the truck
Nachricht 5 von 15
Just share the family here.
Nachricht 6 von 15
emersongonzalez1999
Here is the files
Nachricht 7 von 15
View Phase Filter set to "Show Complete"?
Nachricht 8 von 15
Nachricht 9 von 15
als Antwort auf: barthbradley
It's a Revit Specialty Equipment Family.  It is colorless. Paint it.
Nachricht 10 von 15
Nachricht 11 von 15
So I have to do manually ? like edit materials ?
Nachricht 12 von 15
It is an actual Revit model, I am impressed.  You need to assign materials / paint surfaces 3d elements in the family.
Nachricht 13 von 15
Just open the Family, create some colorful Materials, and then paint the Truck with those Materials using the Paint Tool.
Nachricht 14 von 15
syman2000
You are better off with this family instead
https://www.revitcity.com/downloads.php?action=view&object_id=7696
Nachricht 15 von 15
If you want to make a job of it, you could Paint with Instance-Type Material PARAMETERS.
See this link to learn more:
BIM Chapters: Revit Materials; Painting a Material Parameter
