Family Behavoir
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
PhilvK
461 Aufrufe, 9 Antworten
Family Behavoir
I created a base cabinet family a while ago. The project it will be used in will have different base cabinet widths, and maybe different heights. The widths can be individually changed without affecting others, but changing the heights affects ALL cabinets. When I go into ‘Family Types’ I don’t see any indication on which parameters are instance or type. How do I find that info and change it? Thanks!
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: PhilvK
Types show under the Type Properties and Instance shows under the Instance Properties. For instance, if you select the family in the browser, you can right-click on it to check its Type Parameters. If you select an instance of the family in the project, its Properties will display those parameters/values  assigned to it. Regarding changing them: you need to do that in the family itself.
Nachricht 3 von 10
PhilvK
als Antwort auf: barthbradley
Thank you, and yes I can see that in the Project Browser. I can't see the difference thought in the family type info and don't know how to get the height to be an instance parameter. See below for what I am looking at:
Nachricht 4 von 10
like I said: that's something you do through the family itself - not the project.
...your screenshot looks like it's from the family. Those are all Type Parameters (no "default", except for the "Width" parameter). Just edit them and make Instance.
Nachricht 5 von 10
Your screenshot indicates Height as Type param and Width as Instance param already. Load it in project with Override parameters option selected.
When you select instances in project, Width should appear in the properties and you can enter the value there, Height must be reveal via Edit Type.
Nachricht 6 von 10
als Antwort auf: ToanDN
What?
Nachricht 7 von 10
Sorry. Misread the question. Yes you need to change the Height to Instance param as well.
Nachricht 8 von 10
Just having fun with you Toan. Smiley (fröhlich)
Nachricht 9 von 10
PhilvK
I got it now. My problem was that I wasn't seeing how to edit the parameter, but I do now. Thanks to both of you!
Nachricht 10 von 10
Toan: Thanks to Phil, I'm closing in on you for number of "Solutions" offered. I'm now only 555 behind you. Watch out; I'm on your tail! HA!
