Family array - Can't generate label (parameter) for array items
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
jvpantin2
548 Aufrufe, 5 Antworten
I'm creating a famly with a single extrusion that I want to array and then change number of items with a parameter. I've done this before but it's driving me crazy I can't find the label to create the parameter. I've made the family nested as I remember, what could I be missing? Thanks in advance,
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
5 ANTWORTEN 5
Nachricht 2 von 6
pedruccioli
als Antwort auf: jvpantin2
If I understood it correctly, what you need is to select one of the array items, then click on the line with the number of items (the array control). On the properties of that line, there will be a label option, where you can set it to a parameter.
Architecture Modelling, BIM Workflows and Information Exchange.
LinkedIn
Nachricht 3 von 6
jvpantin2
als Antwort auf: pedruccioli
Yes, I remember that, but it's just what doesn't show on the ribbon...
Nachricht 4 von 6
pedruccioli
You have to select the line, not the number.
LinkedIn
Nachricht 5 von 6
jvpantin2
Genius @pedruccioli, thanks a lot! It was driving me nuts...
Nachricht 6 von 6
pedruccioli
Glad I could help :leicht_lächelndes_Gesicht:
LinkedIn
