All,
I am having a few issues that I think might be easy for someone really good with array parameter skills, if you could take a look I would really appreciate it.
I am trying to have the top hooks level have a hard 6" from wall on either side, with an max distance of 3' apart. while on the lower hooks be in the middle of those equally.
See attached family
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Is Array Spread it Fit? Sounds like you need a Number formula?
Number (Integer) =((Overall Length-(2*0'-6"))/3'-0"
Array to Last (spread to fit):
HookArrayNumber=roundup((Length - (2 * 0' 6")) / 3') + 1
I am going to have to spend some more time later looking this over, so I can understand. but much appreciated.
Thank you
