Dear all,
The cubicle family in the attached file appears to behave strangely. When placing an elevation line beyond the front face (Elevation 'Typical Cubicle-C') - but still within the object depth, it still shows the front of the object (Cubicle doors & pilasters). I wish for it to show the object (IPS panel) beyond with the cut cubicle dividing panels.
Any assistance and explanation on why this object is behaving like this would be greatly appreciated.
All the best,
Jake
Gelöst! Gehe zur Lösung
Gelöst von alan.johnson7YLND. Gehe zur Lösung
If you use older Revit versions then change the family to Generic Models category.
Thanks all - resolved by (1) Enable Cutting in Views alongside (2) deleting the 2D dashed lines within the object (as I could not see a solution to turn these off).
