Families wont load properly
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
832 Aufrufe, 11 Antworten
I am working with generic wall based families on revit.
The families are made of solid extrusions & void extrusions and all elements locked with reference lines/surfaces and later grouped together.
When I load these families to a project, it does not load properly.. Am I doing something wrong while creating this? Cause there are no instance parameters or anything that I am changing in the projects..
Family View -
In Project View :
Parameters:
Tags (3)
11 ANTWORTEN 11
Nachricht 2 von 12
Avaris.
als Antwort auf: Anonymous
I think the details are only visible in fine mode. Try to set your detail level of the view on fine.
Nachricht 3 von 12
als Antwort auf: Avaris.
No.. I tried that - the family is distorting after loading it..
Nachricht 4 von 12
Alan.johnson1970
can you attach a copy of the family?
AJ.
Nachricht 5 von 12
als Antwort auf: Alan.johnson1970
PFA
Nachricht 6 von 12
Alan.johnson1970
un grouping seams to work for me
AJ.
Nachricht 7 von 12
jeroen_vanmassenhove
Might have something to do with the several groups?
I tried to load the family inside a project, same behaviour you encounter ( very thick plate and the braille on the wrong side etc)
I then ungrouped 3 model groups and then reloaded it into the project. Seems to work!
Nachricht 8 von 12
als Antwort auf: jeroen_vanmassenhove
The problem is, Base height of the family is an instance parameter & if I don't group them, then they all move differently... Is there a way to get around that problem?
Nachricht 9 von 12
Alan.johnson1970
Maybe try nesting.
Create each bit of text as its own family and load into this family, you will probably have more control then.
AJ.
Nachricht 10 von 12
Your family is unwieldy, over-constrained and improperly constrained, and way too big at 1452 KB.
One of the main problems I see with the family is you have a lot of very, very small sketch line segments.  Why aren't you using Model Text?
See attached Revit file.  I think it may help you.
Nachricht 11 von 12
als Antwort auf: barthbradley
I tried using model text but the font to be used distorts the text completely.
Nachricht 12 von 12
Okay, so for that text (Arabic?), I'd model it in a separate family and nest it into the placard host family, and then align and lock to x & y Ref. Planes intersection.  Avoid all the grouping you got going on too.  Align and lock all geometry (and nested families) in the host to Ref. Lines driven by labeled dimensions or locked in place with dimensions.
