Families - starting view
23 ANTWORTEN 23
Nachricht 1 von 24
htews
2390 Aufrufe, 23 Antworten
when opening a family, is there a way to change the starting view instead of the 3D view, open it with the floor plan.
thank you.
23 ANTWORTEN 23
Nachricht 2 von 24
als Antwort auf: htews
Revit opens the Family in the last view it was saved in.
"Family" and "Floor Plan" is same sentence doesn't compute.  Are you meaning a Project?
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2018/...
Nachricht 3 von 24
htews
als Antwort auf: barthbradley
when I open a family, it opens to the 3D view.  Im constantly opening up the plan view when I want to edit the family .rfa, close the 3d view, edit what I need to and then save and reload back into the project.  then when I need to make another edit to the same element, it opens to the 3d view again.  happens to all the families I open.  I know how to edit the starting view for a project but not a family .rfa file.
Nachricht 4 von 24
So you are saving the family in plan view and then closing?  And then when you reopen the file, it's back at 3D?  Strange.
Nachricht 5 von 24
Shot in the dark suggestion for you....
Nachricht 6 von 24
RobDraw
There doesn't appear to be a way to assign the starting view. In fact, the starting view button is present in the family editor but it is grayed out.
Rob
Nachricht 7 von 24
als Antwort auf: RobDraw
Did you verify, @RobDraw? Using what version?
My 2018 saves and reopens just as I described above.
Nachricht 8 von 24
RobDraw
I didn't try your suggestion because I thought you were guessing without testing. That box is for the thumbnail preview and seemed unrelated.
Your method does work.
Rob
Nachricht 9 von 24
htews
correct and Revit 2018.3
Nachricht 10 von 24
You're right about that last one. It was a shot in the dark.  Did I miss? he,he.
Nachricht 11 von 24
Try deleting the 3D view from the family and saving and closing and re-opening.  .
Nachricht 12 von 24
htews
tried that too.
Nachricht 13 von 24
What??? Maybe I'm misunderstanding what you are doing. What Family and Category is it?
Can you post your workflow step-by-step (e.g. 1,2,3)?
Nachricht 14 von 24
RobDraw
@htews wrote:
tried that too.
Are you saying that @barthbradley's suggestion doesn't work for you?
Make sure to pick the appropriate source view in addition to checking the box.
Rob
Nachricht 15 von 24
htews
huh...when I open a family either from outside of revit (windows explorer) OR from File - Recent Documents, the family opens to the 'Ref. Level' AND the File Save Options Thumbnail Preview Source is set to the same Ref. Level.
But when I open the family within revit via Project Browser / within the model / select and Modify menu and pick Edit Family, it opens to the 3D view and the File Save Options is set to 3D view for the thumbnail.
any thoughts?
thank you
btw, this is happening in both '18 and '19.
Nachricht 16 von 24
Edit a family from a project opens a new file, not the RFA you saved to a family folder. Only when you save and overwrite it becomes an RFA. Now load it back in your project, close the file, and edit family to open it again, what view are you seeing?
Nachricht 17 von 24
I can bounce back and forth between Project and Family with losing the last View orientation.  Are you saying that you are reloading and closing family and then reopening from Project.  Well then, it's going to open in the in-built "View1". That's the way it has always been.
Nachricht 18 von 24
htews
I would assume like most people, open the family from the model, edit, and then reload back into the model.  It's just annoying and extra steps to open the Ref. Plan, close the 3D view, and then make the changes, and reload back into the model.
Nachricht 19 von 24
I guess if I was constantly opening families and editing them while working on a Project, it would be terribly frustrating to me too.  But, I don't usually work that way.  May I ask why you need to?  Are you creating new Types within the Family? You know, you don't necessarily need to open the Family to do that?
..still, just to be clear: you shouldn't need to switch views if the family is currently open. I mean, if it is left open in Floor Plan View, and you are switching back and forth between the Project and the Family, the view should remain the same as you left it.
Nachricht 20 von 24
RobDraw
What people do with families can vary quite a bit depending on responsibilities, workflows, type of families, etc. I'm wondering why you need to edit families multiple times. So much so that you are willing to take extra steps to assign a particular view for future edits.
@barthbradley, you beat me to the punch.
Rob
