Families no longer rotate
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
redhouse.j
191 Aufrufe, 2 Antworten
Hi, I am not certain when exactly this happened, but I've just noticed that I can no longer rotate any families. I think I've been running 2022 this entire time and was able to do this before. Toilets, sinks, appliances, etc. will no longer rotate with the rotate command. No, they are not wall-based families. There is no error message given. Everything seems in order, but once enter is pressed, the object remains in its original location. The only way I can seem to rotate objects is to draw a random line on an angle, then align the object to it until it can finally align it to 90 degrees. These are old families from my library built up since 2006 and they have functioned properly until now. Is there some recent toggle/setting that has gone into effect where all families need to be painstakingly fixed? I hope not...
2 ANTWORTEN 2
Nachricht 2 von 3
curtisridenour
als Antwort auf: redhouse.j
check the disjoin button?
Nachricht 3 von 3
redhouse.j
als Antwort auf: curtisridenour
Awesome! Yes, I must have clicked that on by accident not knowing what it did. Thanks!
Jeff
