FAILURE IMPORTING DWG
5 ANTWORTEN 5
Nachricht 1 von 6
426 Aufrufe, 5 Antworten
I'm trying to insert a dwg file in an existing revit file via link CAD and via import CAD, but the same error mensage keeps appearing.
I already tried pasting the dwg drawing into a new file, with only one layer, totally exploded, into proxygraphics 1 and saved as an older version of autoCAD, but nothings changes.
The mensage that appears is the one in the photo. Does Anyone knows what it going on and if there is still a chance to fix it?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
The drawing maybe from a vertical such as Autocad Architecture, MEP, or Civil. Have the authoring program export it to vanilla Autocad format before bringing it to revit
Nachricht 3 von 6
als Antwort auf: ToanDN
How can I do that?
Nachricht 4 von 6
Did someone give you the drawing or did you create it?
Nachricht 5 von 6
Someone gave me the revit file and another person gave me the dwg drawing. But a transfered the dwg into another autocad file.
Nachricht 6 von 6
Ask the one sent you the cad file to export it to vanilla AutoCAD 2013 format then send it again.
