Failed to print PDF Revit 2018
2 ANTWORTEN 2
Nachricht 1 von 3
423 Aufrufe, 2 Antworten
Revit will not print PDF.  It says that it was not able to start the print job because it was unable to connect to a specific printer.....I am printing PDF not to a plotter.
2 ANTWORTEN 2
Nachricht 2 von 3
jeroen_vanmassenhove
als Antwort auf: Anonymous
Since 'printing to PDF' is sending it to a virtual printer, doesn't mean Revit knows it's a printer or a virtual printer.
What PDF printer are you using? Common PDF printers being used are for example CutePDF or PDFcreator, both which are free.
Nachricht 3 von 3
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community! I see that you are a new visitor! Smiley (fröhlich)
Please see the cause of this issue Revit error: "Revit could not start the print job because it was unable to connect to the specified printer" and solution on this article
Let me know if you have any questions and if this helps! I look forward to your reply update.
Please select the Accept as Solution button if my post solves your issue or answers your question. Likes welcome!
