I tried to open a recent project that I was working on and I get a "failed to open" message when trying to open it. I've never had this before. I've tried to open with auditing and using the web viewer, neither work. Any ideas?
Attached is the link to the file as well.
https://1drv.ms/u/s!Apu8H0uSfAiHtpBwSKA2yyexxR7aRw?e=yZWWCT
How about trying like these ways?
Could you try copying the file to different location on your local system and try opening the model again. I attached the link so that you could also check the other ways. I hope it helps you.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-Journal-reco...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-Failed-to-op...
use the Audit for link and save it then open project in the same way , whit checked Audit.
Hi @jvalaleducation, thank you for attaching the file. I check it an the model is physically corrupted, we cannot restore the data. When trying to open the file, in the journal the following error is logged:
"Load exception "COleException", code=0x80030109: The docfile has been corrupted."
Do you have any backups available that you can use?
This corruption usually happens when the binary data is not properly saved on disk. Where do you store the models and what tools/workflows do you use to transfer the files?
Having an unstable network connection might be a cause for this kind of corruption. Revit communicates with the cloud (ACC, BIM 360) by sending and receiving chunks of data, called element streams. If a stream is not downloaded correctly or only a part of the stream is downloaded because the network connection was interrupted, the model might get corrupted.
Whose "cloud"? Not all clouds are equal, especially with Revit files.
Steve Stafford
