Failed to open document.
3 ANTWORTEN 3
Nachricht 1 von 4
NicolasMossoux
317 Aufrufe, 3 Antworten
We've saved a revitfile yesterday and now it won't open. 'Failed to open document.' Is there any solution to recover this file? There are no backup files. Thanks.
3 ANTWORTEN 3
Nachricht 2 von 4
ennujozlagam
als Antwort auf: NicolasMossoux
hello, try to tick audit before opening the file and see if helps. thanks
Nachricht 3 von 4
NicolasMossoux
als Antwort auf: ennujozlagam
Still the same problem...
Nachricht 4 von 4
I would try and open it with a doc viewer, if the values are all 0 it's lost for good.
You might not be aware how to do that, if not I would suggest reaching out to Autodesk Support, they are usually pretty good at answering and competent.
Manuella
