Hi.. I am trying to open a revit file sent to me by a third party however I get a ''failed to open document'' notification when my revit opens.
Could this be because my version is 2014 and the file I'm trying to open was created in a newer version ?
Thanks in advance
Gelöst! Gehe zur Lösung
Gelöst von mpeperkamp. Gehe zur Lösung
@Anonymous,
If the model you have received a higher version is you get a message from that.
What you can try is to turn on Audit when opened.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi @Anonymous,
If you open Revit and then to the "big R".
There you click on open and select the model.
Before you click open select to audit as the picture can be seen in my previous post.
Hi @Anonymous,
If my post was useful to you, would you be so kind and accept is as a solution.
Others can see That and Find That information better.
Hi, as feedback, this option did not work for this message. The error message still occurs.
With thanks,
@mpeperkamp wrote:
@Anonymous,
