Got the below warning when trying to upload a model I have previously uploaded to Dalux again. Im in the process of clearing out all the warnings such as the identical instances and room separation lines overlap but I think all of them were actually there in the last upload. Ive done a full reset of my laptop and that hasnt helped. Anyone encountered this and fixed it before?
Failed to access print parameters. at Autodesk.Revit.Proxy.DB.InSessionPrintSettingProxy..ctor(ADocument* pADoc) at Autodesk.Revit.Proxy.DB.PrintSetupProxy..ctor(ADocument* pADoc) at Autodesk.Revit.Proxy.DB.PrintManagerProxy..ctor(DocumentProxy pADoc) at Autodesk.Revit.DB.PrintManager..ctor(Document pADoc) at RevitPlugin.BuildingExplorer.BuildingExplorerExport.FixPrintSettings(Document doc) at RevitPlugin.BexExport.Execute(ExternalCommandData cmdData, String& msg, ElementSet elems)
Tried a google search on the warning and found that it could be related to printer drivers, corrupt printers on the PC, permission issues or that the system doesn't have a default printer. Which means when Revit is trying to access the printer you get this error. It can be that it tries to access one of the printers you are not trying to use and that one is corrupt somehow. Could be something to look into at least.
You can read more here:
