Face to wall option issue
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
475 Aufrufe, 4 Antworten
I insert my drawing by conceptual mass but there i cant create wall or other things from my autocad drawing. Could someone give a hand here with this?
4 ANTWORTEN 4
Nachricht 2 von 5
dzanta
als Antwort auf: Anonymous
this is sort of unclear....
If you insert a 2d cad file into revit, you can use it as a background to draw your 3d revit content (i.e. in plan view for walls)
If you insert a 3d cad file into revit, insert it into the default {3d} view.  From there, it is a single, imported entity that you can reference against to build your 3d revit model
If you created a 3d mass object (from the mass.rft file), you should be able to insert this into the project and then use the Building Maker Tools (wall by face, floor by face, curtain system by face, etc.) to create your 3d revit file.
what are you trying to accomplish?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 3 von 5
als Antwort auf: dzanta
the last one is what i need.. have i can create my dwg 3d model to mass and import it in revit to use wall by face etc options?
Nachricht 4 von 5
dzanta
see the following videos on how to use the Building Maker Tools:
Floors by Face
https://www.youtube.com/watch?v=tUrx41KPftY
Roof by Face
https://www.youtube.com/watch?v=JcNxfADlKWM
Wall and Curtain System by face is same method
Nachricht 5 von 5
mushimmx
I import 3D MAX model in revit with the help of conceptual mass tool  for creating .IFC file with category like Wall, Floor, Door etc.but revit restricted me to change element category. Please see the screenshot.7-2-2021 1-44-44 PM.jpg
