Face based Family keeps sides vertical
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
sascari
514 Aufrufe, 9 Antworten
Is there any way to make a face based family that keeps the sides parallel and vertical but the top face attaches to the floor face?
9 ANTWORTEN 9
Nachricht 2 von 10
raythong980707075652
als Antwort auf: sascari
Check if your family reference place are set to an angle?
also check if there are anything driving your family to be at an angle
Nachricht 3 von 10
sascari
als Antwort auf: raythong980707075652
I'm using the face based family template. I don't think there are any angles set in place... Should I be setting some angles? A little more info would be helpful. Thanks. Revit_roBuhZRuv5.png
Nachricht 4 von 10
Edit the  family and tick Always vertical.
Nachricht 5 von 10
sascari
als Antwort auf: ToanDN
@ToanDN
I don't think that option is available in the face based family. This is my goal essentially:
-> Purple follows face
-> Green stays vertical
Nachricht 6 von 10
What exactly you are modeling?  With what you show, if the sloped surface is a ceiling or floor then model the vertical element as a column and attach the top or base to the slope.
Nachricht 7 von 10
There are Revit Lighting Families available on-line that pivot. The pivot angle is parametrically controlled.  You can build it yourself too.  Download and reverse-engineer one that does pivot to learn how to do it .
Nachricht 8 von 10
Nachricht 9 von 10
Nachricht 10 von 10
sascari
Very cool. Thanks guys!
