Hello everyone i was wonderig wich method will you use to do a facade with metalic panels ans profiles like in the photo.
I´m not sure if I´ts plain or it has some setoff
Thanks in advance
Gelöst! Gehe zur Lösung
Gelöst von freeriderfx. Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
The ridges and valleys of the surface are the mass form. The panels lie flat on the surfaces of the mass.
you can do it by using:
https://knowledge.autodesk.com/community/screencast/69591a78-1ae2-4ffa-a2c0-7d301b8273d0
Constantin Stroescu
IS THE A WAY TO MAKE A CONNECTION LIKE THIS???
HOW TO MAKE A STRUCTURAL CONNECTION LIKE THE ONE OF THE PICTURE????
