Hi.
I have import a section of a model created in fabrication into Revit by useing MAJ file import facility. it tells me that the model has loaded sucsefully but when the model is intergated that fitting are not joining node to node but they are in fabrication. I open the save Revit file in navis and looks OK.
Can explain the reason for the fitting not joining in Revit. see image below.
Solved by Viveka_CD. Go to Solution.
I see that you are visiting as a new member. Welcome to the Autodesk community
Make sure the database is the same inside Revit. See HERE for more information
If you are looking to place fabrication parts in a Revit model please see HERE
Please look at a similar discussion HERE
Take a look at this screencast HERE
Let us know if you were able to resolve this issue or we can troubleshoot further if you send us the file.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
We haven't heard back from you! I just wanted to follow up here, any progress on this issue?
If you are not able to resolve send us the file to troubleshoot further.
Please mark any posts that help with "Accept as Solution" and thanks!
Viveka CD
