I am trying to create a family where in an extrusion there is a bend, that is depended on several parameters. The bend needs to move when I change the parameters A, AA, B, BB and R. If I understand correctly I first need the calculated the center point for the bend. So that is why I made X en Y parameters. But I don't know how to calculated X and Y, can someone help me with this or offer me a different solution?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
If you draw the extrusion with all of the lines intersection at the reference plane intersections, it will automatically adjust. I did a quick video on what I mean.
@Anonymous I use Generic model adaptive. It is Revit 2017 format.
EDIT: regular generic model works too.
I saw there are many answers...Anyway as long as I did a try I put it here...in Revit 2016
Constantin Stroescu
Thx for the families and video's. But we're not quiet there yet. I need R to be a variable and not a reporting parameter.
The adaptive family(family2) from ToanDN is working as I need it to be. But there is a problem with the adaptive family, I can't make the category a mechanical equipment, what I need it to be. And Revit doesn't allow for an adaptive family to be nested in a mechanical equipment family.
@ToanDN the family1 you made, isn't totaly working. When I adjust parameter AA, the bend doesn't move.
@Anonymous , If the Family2 that ToanDN posted is working, then, simply reproduce that family in a mechanical equipment family, and please mark his post as the solution.
@Alfredo_Medina, I can't reproduce the family2 from ToanDN in a Mechanical Equipment family, because adaptive extrusion is not support in a mechanical euiqpment category.
By "reproduce" I mean : make again the same reference planes, parameters, etc, in a generic family, mechanical equipment category. I did not say load, but "reproduce", repeat.
@Alfredo_Medina, your solution is tried bij ToadDN, in family1, where the bend doesn't move with parameter AA. I Have the same problem. In family2 a form element is used, where apparently it will work. But a form element I can not load in mechanical equipment category family.
You keep saying that you cannot load Family2 into a mechanical equipment family.
You have already received 95% of the solution to your problem. Please do the remaining 5%, which is to reproduce the same geometry and parameters in a new family.
I just tested family 1 and it works as intended. Try the attached file again.
