While I was doing the extrusion for a dining chair seat, it comes up as just a line on the front elevation view instead of a block. I tried changing the extrusion end but no matter what number I change it to, it's still the same. What could have gone wrong and how can I fix it?
In the Family. Select the extrusion and look for Visibility Setting under its Properties or on the Contextual Tab.
...let's back up a second. You are creating an Extrusion? Did you click Finish yet?
...do you mean you are seeing a magenta line in elevation like this:
can you share your file so we can check? thanks
