Extracting the information from multiple projects
3 ANTWORTEN 3
Nachricht 1 von 4
michalina.rusinek
239 Aufrufe, 3 Antworten
I am working on multiple projects where I need to extract fixture count and square footage per brand across multiple stores. Each store is saved as a separate project.
For example, Brand X is located in 7 stores- is there a way to combine schedules from all 7 stores to see the sqft and fixture list for each of them in one master schedule?
Thanks for your help.
Mia
3 ANTWORTEN 3
Nachricht 2 von 4
Revit API!
Sounds like you need to program a custom Revit plugin :zwinkerndes_Gesicht:
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 3 von 4
RDAOU
als Antwort auf: michalina.rusinek
@michalina.rusinek
Sounds like you need to look into using Revit DB Link (it ships with Revit, nothing custom which you need to purchase) which basically links your project/projects to a database...See the following help section on what it does.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-D...
Nachricht 4 von 4
Link the models in a master file, create schedules and enable Include Elements in Links under Fields tab.
