Hello you all.
I am looking to extract a value from a family name as the family names are actual internal codes.
As an example, I have a family named B2-5C. The first number relates to the length of this product. I need a way to extract that first number as a parameter isolated from the rest of the code. We already have the length as a parameter. But it is not linked directly to that first number. At present, we enter that first number manually. But is there any way to add a parameter that would strip out the rest of the code and leave that number as parameter automatically without manual input?
Regards
J
Hi @jacques
Its been a while and I'm checking back to see if you've made progress on this issues and if you still need assistance from the community.
Please see: How to set ‘Formula’ for parameters in family and you can use strings to define custom parameters as mentioned by @L.Maas
See this thread on Get All Parameters form Elements and also try posting on the dynamoBIM forum for further feedback.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
