we have tried extentions on Revit 2015 for workstation autonumbering it works but since we start our work on level 4 it number plans like ( 4 for level 4 - 4-1 for floor 5 and so on ) how we can correct this and generally could w correct it manually?
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
Thank you for your posting @Anonymous.
Do you have any screenshot for this, or any sample file? If you run as a new rule, you will have an option to override existing results. If you need to modify a small number of elements, you could use schedule for modifying Marks.
@Anonymous hello, have you tried this? go to your Project Browser > right click the name of views you want to change > rename it manually. thanks
