On Friday I left the office and everything was fine but today when I was trying to check something in the model I kept getting the following popup warning when opening Revit. Any Ideas how to resolve? I tried the solution on this link but it seems not even related. The folder they mentioned is already empty. I also checked the folder which is in the warning and it is also empty and cannot find the mentioned dll on any drive.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
All relate to Interoperability tools. Did you uninstall or update the addin in the past two days?
Also see following link - same topic as yours
I did not uninstall or update. Maybe the IT did in the office but I can still see the tab for Interoperability in Revit so it is for sure not installed.
Then most probably they updated without first removing the older version of the adding. Not knowing which version you've got, I would suggest that you do the following
Go to this directory C:\%USERPROFILE%\AppData\Roaming\Autodesk\Revit\Addins\2020
Remove the following files
BIT.10.ClassificationManager.addin
BIT.20.ModelChecker.addin
BIT.30.COBieExtension.addin
Should fix it ...
In my case I'm using Revit 2025 and unable to use environment plugin as Jason mention to remove (%USERPROFILE%\AppData\Roaming\Autodesk\Revit\Addins\2025) files , but my folder is empty
I am not able to export NWC files from Revit as Export to NWC option is missing in Export Tool
