Exterior Walls
6 ANTWORTEN 6
Nachricht 1 von 7
1508 Aufrufe, 6 Antworten
Exterior Walls
Where can I find the walls to load from the US Imperial Folder?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Create a new project from the Architectural template (or open the template directly), then switch to your project and go to Manage > Transfer project standards > Walls to transfer them from the template to yours.
(Walls are system family so they do not exist as external families in the library lie doors or windows.)
Nachricht 3 von 7
als Antwort auf: ToanDN
how to find the exterior-10" concrete wall?
Nachricht 4 von 7
That's it? Just edit a Generic type, change Function to Exterior, edit Structure, change Thickness to 10" and material to Concrete.
Nachricht 5 von 7
There are no System Families, such as Walls, Floors, Roofs, etc., in the Library.  What the Library contains is Loadable Families -- a whole different animal.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
FWIW:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Nachricht 6 von 7
ennujozlagam
it could be libraries and template are not installed, you can refer to this LINK and see if helps. thanks
Nachricht 7 von 7
hmunsell
als Antwort auf: ennujozlagam
if you have a project that already has that wall in it, do a Transfer Project Standard.
  • open the file that has the desired wall
  • Manage ribbon > Settings > Transfer Project Standard
  • pick the file from the list
  • pick CHECK NONE!
  • scroll down the list and pick the Wall Type option
  • select OK
 this will transfer all the wall types from the selected file into yours.
Howard Munsell
