Exterior wall wood stud detail
3 ANTWORTEN 3
Nachricht 1 von 4
amirhossein.jafarii
1362 Aufrufe, 3 Antworten
Hi all,
I wanted to check ad see if I draw the wall detail properly.
so the construction is wood stud (the building is in Petaluma CA)
we have two layers of 5/8" Gypsum (this is special case)
then we have wood stud 2 x 6
then we have rigid insulation 1"
3/8" vented insulation
then we have sideboard
attached image is the wall details.
first of all I wanted to check if the detail is correct?
second I wanted to know how to draw sideboard detail? I can't load repeating detail I don't know why.
I have the foundation made correctly I wanted to check the wall details.
I have attached the image of the wall detail.
Thank you,
Amir
Tags (1)
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
Studs are the "Structure".  Gypsum is "Finish".  Also, place Stud/Structure Layer at Core and other Layers outside of Core.
Nachricht 3 von 4
Nachricht 4 von 4
als Antwort auf: amirhossein.jafarii
Edit: move the membrane layer to outside of the insulation layer.
