extensions for revit 2020
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
17297 Aufrufe, 9 Antworten
where can I get extensions for revit 2020?
9 ANTWORTEN 9
Nachricht 2 von 10
aRcHiTeCt.JM
als Antwort auf: Anonymous
…. so far I found these …
Revit DB Link 2020:
https://up.autodesk.com/2020/RVT/54345FD2-A8C4-43AC-8282-8CB7DE36D324/RDBL.msi
Revit Site Designer Extension 2020:
https://up.autodesk.com/2020/RVT/D4417057-C379-4704-A8F3-C0A52788A55E/RSD.msi
Revit InfraWorks Updater 2020:
https://up.autodesk.com/2020/RVT/88E71E49-D722-42CB-9DA4-10E6A9CA22A7/IWExportToRevit.msi
Roombook Areabook Buildingbook for Revit 2020:
https://up.autodesk.com/2020/RVT/A70D06BE-685B-4C40-9A53-1C785E8074A8/ABRB.msi
.... I will upload more as soon as they are released ...
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 3 von 10
als Antwort auf: aRcHiTeCt.JM
Thank you
Nachricht 4 von 10
aRcHiTeCt.JM
.... Advance Steel Extension
http://up.autodesk.com/2020/RVT/6357EDD5-5634-42AA-9A2C-4785AE3A5D8D/RSCE2020.msi
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 5 von 10
Can you give me a download link for Revit extensions for fabrication?
Nachricht 6 von 10
Yes please, can somebody help us with MEP Fabrication parts, where download it another contents please.
Thanks!
Tags (1)
Nachricht 7 von 10
support103
Nachricht 8 von 10
bonbilaoen
Hi all,
I have a problem opening BIM360 project in Revit2020 my project links are missing, "add-ins are not installed" appears. Thanks for any resolution on this.
Nachricht 9 von 10
N00202733
buenas tardes cada vez que abro revit 2020 me sale esta anuncio "rendering feature are currently disabled you must install the rendering library to use rendering features" alguien puede ayudarme'?
Nachricht 10 von 10
pendean
als Antwort auf: N00202733
