Extending or aligning beams into another beam or changing reference of beams
Trying to align or extend beams of a beam system into another, perpendicular beam.
Some of the beams can be extended by changing their reference (Modify > Structural Framing > Change Reference).
However, in this particular case, the beams where there is a wall on the floor above, don't allow this. The Change Reference button just doesn't work anymore. These specific beams are also a bit shorter than the other ones in the same beam system. When moving the wall on the floor above, the beams follow this by automatically extending. So they must be connected to that wall somehow. Neither unjoining or changing reference works.
Screen cast of issue
We've run into this problem multiple times in more than one project and are, of course, looking for a solution.
Hello Bram,
do you think you could maybe draw another level at the height where you want to put the beams. And then draw the beams on this level, so they won't get in touch with the wall.
I would do this as a first test, and if it works we can think about whether there is a more elegant solution to this.
Greetings,
Jacqueline
Pieter.DeBleser
Hello Jacqueline,
Took your suggestion, gave it some thought and it worked!
In our template we have about 10 levels standard. Every level indicates the top of a floor. Attached to each level, we have two reference planes; one that indicates the bottom of the floor and another level, a bit lower to indicate the height of the ceiling of the floor beneath.
Changed the work plane of the beam system from "level 1" to "Reference plane - ceiling" and the beams extended all the way to where they should be. I then moved the boundary of the beam system one cm away from the core of beam in which they are placed (for clarity in the construction plan).
Its a common way of building extensions to brick houses where we live. Open up a wall and support levels above with a wide flange beam. Build extension. The roof of this extension is usually a beam system topped off with plywood boards, insulation panels and rolled asphalt roofing.
Thanks for your help!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
